mp 170 recoat - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2004, 07:56 AM
mp 170 recoat
Painting a semi cab that is mostly aluminum and it was sugested that I use omni polyester primer over the aluminum panels but use omni mp 170 over the bare steel parts first. What I need to know is if I spray the polyester primer over the mp 170 after it has sit for 24 hrs do I need to sand the 170 first or can I just spray it without sanding?
Old 12-08-2004, 08:02 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Should be OK. What does your paint supplier say?
Old 12-08-2004, 08:25 AM
The primer came from the local auto parts and the guy who sold it to the truck owner didnt know much about it. There are no full-time paint stores close by and that has always been a problem here. Thanks for the info
Old 12-08-2004, 11:14 AM
Wiki Edits: 21
I think it will be fine. To be safe, spray a test patch on an old paint can to see fo there is a reaction but I doubt there will be any problem.
Old 12-08-2004, 01:39 PM
Ok I sprayed it, No problems as far as lifting but adhesion was what I was concerned about.
