MP 182 over bare metal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2008, 01:33 PM
chas350's Avatar
Guys is it ok to spray MP 182 urethane surfacer over small areas of bare metal from block sanding filler? I am working on the rear doors of my work van, making my way around it in prep for a paint job. I plan to seal everything with epoxy before the top coat. Using Kirker SS urethane for top coat. Hoping I dont have to epoxy all the filler and bare spots first.
thanks
chas
Old 11-29-2008, 08:53 PM
chas350's Avatar
Anybody???
I wanted to work on this in the morning, hoping for some guidance
chas
Old 11-30-2008, 04:21 AM
BarryK's Avatar
2k primer over small spots of bare metal is done everyday in the world of production collisions shops, with very few problems.
In a perfect world you would follow what the manufacturer says about using their 2K over bare metal, some say never, some say OK.
Whatever the answer 2K primers will stick to metal but not as good as an epoxy and they really lack the corrosion protection that the epoxy has.
Will the paint fall off if you use the 2K this way? No but it could be the difference of getting a door bump in a parking lot or a stone bouncing off the road and you ending up with a stone chip or not.
If the car has any value or going to be around a while, use the epoxy.
Old 11-30-2008, 04:40 AM
chas350's Avatar
Ok Barry, Ill hit it with the epoxy first. It is the back of my work van and will suffer small dings/scratchs. So it sounds like I need the rust protection of the epoxy.
thanks Barry
Sanding down to bare metal anyone have any tips? Hawkvenom67 Body - Exterior 54 11-08-2010 06:00 AM
2k primer on bare metal staircasesurfer Body - Exterior 9 05-16-2005 08:19 PM
Bare Metal Prep PPG 68NovaSS Body - Exterior 3 09-06-2004 06:00 PM
Painting Dilema (Bare Metal 4 4months) 70chevy Body - Exterior 5 08-25-2004 09:02 AM
Bare metal prep 72novaproject Body - Exterior 2 12-19-2002 01:15 PM
