MP170(Epoxy Primer) P-Sheet Info. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2006, 10:51 AM
Guys. I'm reviewing my P-Sheet for my MP170 PPG product and it says " HVLP - 8-10 PSI at the air cap". Man 8-10 PSI at the cap is really not much pressure. I know this is the P-Sheet but what kind of PSI for epoxy primer with a MP-175 Primer Catalyst are U guys using to shoot primer?
MP
Old 03-04-2006, 11:22 AM
Thats at the cap, no way to really measure that without special equiptment. An hvlp reduces the pressure internally, but you still would need higher pressure going into the gun. I would start at somewhere around 40 p.s.i at the regulator on the gun and play around with gun settings till you get it spraying the best. The omni brand epoxy isn't real thick so you wont need a large needle. Probably try to use a pressure so it sprays nice, but not overly high that you waste a lot in overspray. Look on the gun, some say what the max pressure allowed is.
Old 03-05-2006, 07:22 AM
theHIGHLANDER's Avatar
One other thing to consider on this product...do not use it over "DX" etching primers. It will peel off like contact paper. I don't recall if it's on the sheet or not, either sheet for that matter, DX or 170.
Old 03-05-2006, 10:10 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
BUT, MP170 does like to be appplied over metal that has been treated with DX metal treatments.
As to pressure, follow the inlet pressure recommendations from the mfr. of the spray gun.
Primer Sealer ?? Sagacious Body - Exterior 12 12-21-2014 11:11 AM
difference between primer and sealer matty Body - Exterior 3 06-09-2010 11:06 AM
Using a Primer Sealer Hansol Body - Exterior 2 03-28-2004 04:37 PM
Epoxy primer over paint? 1960 Trucks Body - Exterior 4 03-02-2004 02:25 AM
Epoxy Primer lilgto Body - Exterior 2 02-23-2004 05:15 PM
