MPFI 3.1L gm engine hard starting, fuel related - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2009, 07:56 PM
fast68's Avatar
likes chevy trucks & boobies
dont have a pressure tester so im stuck there.
got a 96 or so very common multi port 3.1L engine that is taking extra cranking to get started. put new plugs in it and no change at all. i know its fuel related
any ideas how i can figure out if its the pump or the regulator or ?
i doubt it would be the MAF, or MAP sensors, right ?
actually i think we better put a new filter on it first now that i think of it and at least eliminate that much.
thanks for anything
Old 05-17-2009, 09:41 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can make a temporary pressure tester from an oil pressure gage.
An oil pressure gage that goes to 100 psi works about the best, IMHO- it has a small fitting size that will take a 5/16" fuel hose.
You put a piece of fuel hose over the fitting, hose clamp it securely, put the other end onto the fuel rail fitting (remove the valve from it first) and hose clamp that securely.
Then the pressure can be checked.
Name:	fuel pressure gage 001.jpg
Old 05-17-2009, 09:56 AM
T-bucket23's Avatar
Wiki Edits: 26
Is it hard to start both when hot and cold?
If it is both you could have a bad pump or pressure regulator. You can eliminate the regulator by blocking off the return line temporarily and see if the issue goes away.
A defective temp sensor can also cause hard starting under certain temperature conditions.
The other common issue is a leaky injector that will actually flood the engine when its not running and will cause extended cranking.
Chet
Old 05-18-2009, 04:53 AM
Another common problem is the relay it supplies power for a few seconds to prime the system.After starting ther is an aoil pressure switch on a gm that takes over this is done so that if the engine dies in an accident etc. fuel flow is stopped.Sounds like while cranking once you get oil pressure it starts?
Old 05-18-2009, 04:16 PM
fast68's Avatar
relay no
nothing to do with relay and electrical
the pump always primes and runs etc.
i found the problem though a bit ago
i remembered that we had a 90 something celebrity with the same mpfi style injection engine but 2.8L instead(really same as 3.1L anyways) and it had this same problem where it was difficult to start and took much cranking times to start almost always.
the culprit:
ruptured fuel pressure regulator
raw fuel getting sucked up the vacuum hose to it
so yeah.....................
unplugged it and capped it, and sure enough it fires right up now.
the chevy celebrity all over again de ja voo hahaha
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
fuel injection turned into a carb engine schuffman Engine 3 02-28-2006 01:13 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 07:01 PM
