Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mpg question
Thread: mpg question
Old 04-03-2013, 06:50 AM
delawarebill's Avatar
delawarebill delawarebill is offline
Originally Posted by xzero117 View Post
on a car equipped with a double pumper carb settup
is it better to drive around at say 2000rpm in third gear at 30mph with the gas pedal pressed down 25% of the way
or to drive around at 1200 rpm in 4th gear at 30 mph with the gas pedal pressed down 50% of the way ?
in which scenario would I achieve the best mpg's
it's always recommended to stay in as high a gear as possible for fuel economy, but does that still apply if you're dogging it ?
i may be looking at it wrong?? but i don't see how u can have your peddle depressed more at a lower RPM. if u swap the throttle position in your statement i'd agree..
