-   -   mpg question (http://www.hotrodders.com/forum/mpg-question-231420.html)
xzero117 04-02-2013 04:35 PM
mpg question
on a car equipped with a double pumper carb settup
is it better to drive around at say 2000rpm in third gear at 30mph with the gas pedal pressed down 25% of the way
or to drive around at 1200 rpm in 4th gear at 30 mph with the gas pedal pressed down 50% of the way ?
in which scenario would I achieve the best mpg's
it's always recommended to stay in as high a gear as possible for fuel economy, but does that still apply if you're dogging it ?
37hemidodge 04-02-2013 07:21 PM
I am no expert but the lower gear is going to use less gass in my opinion as it is not dumping fuel it can't burn hence the bucking and bogging ! May be wrong but believe that's better for your motor as well !
68NovaSS 04-02-2013 07:26 PM
I agree. By the same token, a big block pulling a heavy load will get better mileage than a small block pulling the same load, or a 4 bbl getting better mileage than a 2 bbl under some circumstances.
vinniekq2 04-02-2013 10:49 PM
the cam specs also matter.If the cam has a lot of overlap then you need to be a little higher RPM(slightly,not a lot)The accelerator pump on a holley kills mileage.
thinwhiteduke 04-03-2013 12:05 AM
Fill up at a gas station. Record your odometer reading. Drive fifteen or twenty miles in thrid, then turn around and go back and fill up again. Record your gas usage and your mileage. Do the same run again, this time in fourth gear. Fill up again and compare the difference....this way you'll know for sure.
IMO it's better for the engine to be running on cam at 2000 than be labouring at 1200 for any length of time.
If you go through this exercise , please post the result, I'm curious too.....
Duke
37hemidodge 04-03-2013 04:48 AM
Also a four bbl carb has a smaller primary so if you don't pull in the secondary's you will get better mileage out of a four bbl.
delawarebill 04-03-2013 06:50 AM
i may be looking at it wrong?? but i don't see how u can have your peddle depressed more at a lower RPM. if u swap the throttle position in your statement i'd agree..
oldbogie 04-03-2013 09:24 AM
More RPM on less throttle in this case. It does two things, it keeps the air velocity up in the primaries which meters better; it keeps the manifod vacuum up preventing the power valve from coming on.
Bogie
