Mr - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2012, 03:22 PM
Mr
Have a
Campbell Hausfeld Iron Force Air Compressor
single phase 230 volt 60 gallon 2 stage...........trying to wire it from a gasoline generator 8550 starting watts and 5500 normal...............Bought exact plug for 230 outlet on generator anf 4 wire cable ........compressor try to start.....but generator breaker kicks out! Checked voltage at compressor all im getting is 110..........compressor has only 2 terminals for power and a ground. But plug wiring has red black whit and copper ground!!! Any ideas???
Rick
Old 08-18-2012, 05:02 PM
302 Z28's Avatar
What is the current rating of the compressor motor?
Vince
Old 08-19-2012, 06:03 PM
Does the Generator have a 110/220 switch?
Did you wire the plug correctly?
If you have 110v at each term to ground your Gen. ain't big enough.
