Mr. Carrolous Verrill - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Does the 1949 Diamiond T model 509 have a 6 volt battery and negitive ground?
6 volt battery? 0 0%
Negative ground? 1 100.00%
Voters: 1. You may not vote on this poll
Old 09-02-2009, 02:14 PM
I own a 1949 Diamond T model 509 with backhoe. I have question about the battery whether it is a 6 volt & negative ground.
Old 09-02-2009, 02:37 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Everything that I have ever seen that used a 6 volt battery used a Positive ground.
Old 09-02-2009, 05:42 PM
Wiki Edits: 31
GM I know is - ground as well as willys/jeep , my book doesn't cover the Diamond T. but didn't they use the Hercules 6cyl?, which IIRC Chris craft ( boats ) also used.. sorry I can't help anymore than that
Old 09-02-2009, 07:23 PM
poncho62's Avatar
Wiki Edits: 5
Each cell of a battery is 2 volts, so if it gas 3 cells, its 6 volts..........6 cells, its 12 volts.
Ontario Rodders
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 04:36 PM
Mr. Gasket Arcuden Engine 12 10-02-2007 04:27 PM
My First Day With Mr. Hiboy Higirl Hotrodding Basics 9 08-17-2006 11:30 AM
scam the scamers akm Hotrodders' Lounge 19 10-12-2004 10:16 PM
Mr Gasket breathers andybird Engine 2 04-03-2003 02:09 AM
