Mr. Gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2007, 04:02 PM
Perfectionist Procrastinator
Last journal entry: Moving along
Mr. Gasket
Hey guys,
It seems that a lot of people here have had bad experiences, or at least have a bad opinion, of Mr. Gasket. I'd like to know why this is and if these experiences are reason enough to stay away from using their products.
This is the context within which I am working:
383 SBC (.030" over, 3.75" stroke, 5.7" rods, naturally aspirated)
F/T Speed-Pro hypereutectics, 5cc
AFR 195 Eliminators, 75cc
Pistons are .017" in the hole (decks were cut .008" from stock 9.025")
For optimum quench of .040" and a target static CR of 9.5 - 10 to one, I need a gasket thickness of about .023". Mr. Gasket is the ONLY manufacturer that I can find that makes a composition-type gasket anywhere close to this size in part #1134, which is .028" thick with a gasket bore of 4.130. These numbers put me at .045" quench and 9.74:1 SCR which I can definitely live with, but I am concerned about the quality and reliability of the Mr. Gasket part. This is a pretty mild build - no more than 450 HP, N/A.
GMPP makes a .028" composition gasket also, but apparently for a 4.000" in bore only. The only Fel-Pro gasket I can find that comes close is #1094 - a .015" / 4.100" shim which is a bit small, I think, and I've read that shims do not seal as well as composition-type gaskets. On top of that, there is a shim that is .020" thick which is closer to my goal, but you guessed it, it's from Mr. Gasket as well.
For the record, the car is a '70 Nova, 4-speed manual, 3.73 rear, daily driver.
Old 09-30-2007, 04:14 PM
DHMag's Avatar
no bad expereinces here. have had MrG 305 .028 gaskets on mine for almost 2 years now without issues.
Old 10-01-2007, 11:41 AM
Thanks for the reply, DH, but I have one more question for you: Is that car your daily driver, a cruiser, race car, or combination of any of these?
Old 10-01-2007, 11:47 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I have never had a problem with Mr. Gasket, nor have I ever heard of anyone having a problem.
Old 10-01-2007, 11:55 AM
RippinRon's Avatar
There a victor/clevite #5746 0.026" thick 4.100" bore
Old 10-01-2007, 01:27 PM
DoubleVision's Avatar
As for the gasket products of Mr. Gasket, no problems, I used the same .028 thickness gaskets on 2 small blocks, and used countless sets of the intake gaskets with no issues, and I don`t know how many sets of valve cover gaskets, none have given me any problems at all. The rest of the line is just about junk, but there gaskets are excellant, at least they did stick to quality on the gasket line. The chrome timing tabs aren`t great but they do the job, the valve cover breathers are dead within 2 weeks, plug wire looms melt if the slightest hint of fuel is spilled on them or if they get remotely close to the exhaust. Any of the "dress up" items they have is super cheap made stuff that isn`t worth what costs.
Old 10-01-2007, 02:07 PM
302 Z28's Avatar
I agree with DV, the gaskets are fine. They are probably made by a well known manufacturer. The other stuff they sell is pretty much garbage.
Vince
Old 10-01-2007, 02:40 PM
I've used their header gaskets with success, but I agree with DV, it seems the rest of the line (ex gaskets) is pretty junky. One of their alternator mounting brackets cost me a motor. The bracket broke where it hooks over the header bolt, the alternator tipped forward, the belt dropped, that belt jammed in the AC belt, bent the Water Pump shaft and tossed the AC belt. No water pump. I was cruisin' up I5 on a warm Saturday evening, near Coalinga. Radio up high, windows open, enjoying the '69 Vette. Noticed a loss in power. Pulled over. Motor died. Permanently. My wife and waited 3 hours, without seeing a highway patrolman. I would up thumbing it for miles to the nearest "oasis". Yeah, I failed to notice the motor overheating. But Mr. Gasket failed to make an alternator mount that would survive. This was the third one I've broken, the first to cost me an engine, and the last piece of Mr. Gasket junk I'll ever buy.
Pat
Old 10-01-2007, 05:46 PM
Thank you all for your replies, I appreciate it all of the input.
RippinRon, would you happen to know of a vendor who sells that gasket?
Old 10-01-2007, 10:05 PM
DHMag's Avatar
btw, Yes it is used on a daily driver.
Old 10-02-2007, 07:00 AM
RippinRon's Avatar
Any local parts store would carry them or be able to get them no problem.
Old 10-02-2007, 02:17 PM
Ah, I was looking in the wrong places. Thanks!
Old 10-02-2007, 05:27 PM
aka Duke of URL
At one time, MR. GASKET was a quality vendor/supplier. It was bought out (as many quality companies are) and went mainly CHI-COM for their parts and accessories. If you are looking for shiny stuff, just buy from AUTOZONE or wherever.
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 05:36 PM
Mr. Gasket Oil Breather Cap BAD xntrik Engine 5 10-31-2005 09:41 AM
Mr. Gasket two piece timing cover nabx22 Engine 15 12-13-2004 06:39 PM
scam the scamers akm Hotrodders' Lounge 19 10-12-2004 11:16 PM
Mr Gasket breathers andybird Engine 2 04-03-2003 03:09 AM
