Mr. Gasket 5727G on std bore with vortec heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2012, 03:08 PM
I have these head gaskets Mr. Gasket 5727G bore says 4.19 thickness .044
I am running flat top pistons(464664) in a standard bore with stock vortec heads. JEGS Performance Products #555-200103
Hydraulic Flat Tappet Cam & Lifter Kit
Lift: .442"/.465"
Adv. Duration: 272/282
Will this gasket work ok?
also running a 7516 edelbrock airgap intake trying to decide on a carb(suggestions) . leaning towards a edelbrock 1405. any idea what kinda horse power i can expect? I would like some power but dont want to be fooling with it all the time.
thanks in advance
Old 04-25-2012, 03:20 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
That part number is returning any pistons on jegs or summit's websites.
Assuming the deck has not been cut (aka standard deck height of 9.025") and with standard compression height pistons (1.560") you have .025" deck clearance.
Then top that off with a .044" head gasket...
That gives you a .069" squish. That is too much IMHO. Shoot for .040-.045" squish.
Typical rebuilder pistons will have a compression height of 1.540", which in my example above would give you a squish of .089" which is way too much!
Now has the block been decked?
Old 04-25-2012, 03:23 PM
hasnt been decked. Standard block with not much use. They are trw pistons 1.56 compression height from what i can tell.
Which header gasket should I use on my vortec 062 heads?? redfish211 Engine 2 07-12-2011 08:38 PM
what bore should my head gasket be? 383SBC Engine 2 02-07-2010 02:58 PM
454 std bore bizerk Engine 1 05-13-2009 09:05 PM
head gasket bore size GMR Engine 8 10-27-2008 08:04 AM
whats a std bore 400 worth ? Mustangsaly Engine 6 06-10-2007 09:35 PM
