Mr. gasket micro elec. fuel pump enough fuel output for 400 skinny? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2007, 09:04 PM
i'm building a 400 smallblock holley 750 vortec heads. roughly 400hp 480 ft/lbs. i had given to me a brand new mr. gasket micro electric fuel pump. i think their like 35 bucks at local parts store. anyone use them before or know any info on them? i was thinking of possibly doing it inline with my mechanical pump to help boost the pressure but not sure how much that will help. the elec. pump says its good for like 4-7 psi but i have no clue its flow rate. its the 12s model pump says its good for 4,6, and 8 cylinder applications. here is the only decent link i could find to one.
http://cgi.ebay.com/ebaymotors/12V-M...ayphotohosting
Old 01-07-2007, 10:22 AM
TailGater's Avatar
Blood, Sweat, and Gears!
a quick search on Mr Gaskets website found this http://go.mrgasket.com/ProductsListB...minselection=3
they say it flows 35 gph
Old 01-07-2007, 04:52 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
I have one and the spec is 35 GPH at 4-7 psi, which should be plenty for you. I have it installed on my T-Bucket and do not run an engine driven pump on the 350 SBC (300 hp). Very low power draw - I use a 5 amp fuse on the circuit. I also used one of these in an experimental aircraft I built as a boost pump to the engine driven pump - I ran it constantly and no failures in 330 hours of flight time. They are also occasionally seen with a Facet or a Purolator label.
Old 06-18-2013, 08:13 PM
I've got one on my 48 Plymouth (355 SBC, 1406 Edelbrock carburetor, mild cam, no mechanical fuel pump). Works well so far.
Old 06-19-2013, 12:33 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
12V Micro Electronic Universal Fuel Pump 4 6 8 Cylinder | eBay
Your going to run that thing on a 400 HP engine 1 HP per cubic inch!!!! LOL its minimum performance oriented( a cheap replacement pump ( The key word is CHEAP) made for domestic autos to get grocerys!! Of course its junk for your engine combo, its china made by Prestolite!!! Most stock Chevy mechanical fuel pumps flow 60 to 80 gallons an hr. an after market mechanical fuel pump that's designed to work with stock or mildly modified engines delivers a free-flow output of 80 to 130 GPH. and that Mr Gasket (Prestolite) Chinese pump flows 35 gph you do the math and you can answer your own Question! I hate to burst the bubble these guys have, that think they are great, but its a disaster waiting to happen on anything with HP!!!!! I see them used on cars to pick up cans and bottles along roadsides because they are CHEAP!!!!! Take some good advice Dont use it on anything that runs the quarter mile faster then 18 seconds LOL Don't take offense I'm trying to give you good advice in the strongest of terms its up to you to run it or not
Jester
The Following User Says Thank You to painted jester For This Useful Post:
vinniekq2 (07-17-2013)
Old 06-19-2013, 01:24 AM
If you like Mr. Gasket Products Here's the Mr. Gasket pump for a street engine!
I don't run or use Mr. Gasket Pumps! But this is an example of a much better Mr Gasket pump for your combo.
Jester
Mr. Gasket: part # 95P
$105.99
Product Description:
This lightweight pump includes mounting bracket and hardware and is universal for all carbureted engines. 7 PSI max. Not compatible with alcohol or methanol fuels and not for fuel injected systems.
The Mr. Gasket Electric Fuel Pump #95P is a gravity feed vane/rotor type high volume low pressure pump designed for street applications. The operating fuel pressure is factory set at 7 PSI. Normally, a fuel pressure regulator is not necessary. We recommend a 3/8" I.D. hose with this fuel system. #95P free flows at 95 GPH and 65 GPH at 5 PSI.
Old 06-26-2013, 01:13 PM
Don't get that cheap fuel pump they are junk plain and simple. I have a stock 350 vortec when I got my 96 s10 several years ago and that pump left me stranded out in the middle of nowhere and I thought it was old bought a new one and it lasted about two months and that was with hardly any driving and I got stranded yet again but at least was in town and I put a new one on for a third time but just to get me home as I did not have time to set up a new fuel line system to get a different pump on. I eventually got rid of the vortec to fund for a brand new build and this time I got a 350 for a roller setup and a mechanical fuel pump. If you want a good electric fuel pump go to summit or jegs and get a carter fuel pump that goes around 75 bucks give or take a little and it will work excellent for a performance build like yours.
Old 06-26-2013, 07:15 PM
Slammedsi's Avatar
Just buy this and be done.
http://www.summitracing.com/parts/sum-g3136-2/overview/
The Following User Says Thank You to Slammedsi For This Useful Post:
Old 07-17-2013, 08:32 PM
Methinks I spoke too soon...the damned thing quit on me (fortunately while still in the garage). I bought an Edelbrock replacement, but have not installed it yet. Maybe this weekend. I'm beginning to think Mr. Gasket should be renamed Mr. Garbage.
Old 07-17-2013, 10:01 PM
vinniekq2's Avatar
I used one of those cheap electric pumps on a 20 HP Onan industrial engine,it did the job for a couple years,then I bought another one.The Onan pump was too expensive.
Old 07-18-2013, 11:04 AM
I have never had any luck with MR. Gasket products. Check out the fuel pump reviews on Amazon...
Amazon.com: mr gasket fuel pump Amazon.com: mr gasket fuel pump
Old 07-18-2013, 01:08 PM
This thread is from 2007 LOL and the original thread poster (stewartcannon) never came back on
Jester
Old 07-18-2013, 01:31 PM
I didn't notice the OP's date...but I guess their quality hasn't improved during the last 6 years. I guess we're slowly being conditioned to accept poor quality Chinese crap as the norm
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 06:03 AM
should i use a holley blue top or a manual fuel pump? 406 ss monte Engine 18 12-10-2007 08:39 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 04:17 PM
93 dodge shadow fuel pump repair junkie Electrical 2 10-02-2003 09:05 AM
Lean backfire Camaro76 Engine 5 04-15-2003 06:45 PM
