Mr. Gasket two piece timing cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2004, 05:46 PM
nabx22's Avatar
Is anybody using the Mr. Gasket two piece timing cover for a small block chevy with any luck? I just installed one and it leaks like a sift at the bottom where the two covers meet.
Old 12-12-2004, 05:58 PM
Max Keith's Avatar
leaky timing cover
Try some Ultra Copper ATV silicon on it.
Old 12-12-2004, 06:07 PM
lluciano77's Avatar
I have the 2 piece cover.
I used the Felpro oil pan gasket. The extra thick one.
You have to make sure you torque the timing cover on with just enough to get it to seal. Otherwise it will bend the bottom out and start to leak.
Mine had a very small drip that would come out every once in a while. I haven't checked it lately. It think it sealed back up when I retorqued everything in the engine.
Old 12-12-2004, 06:14 PM
nabx22's Avatar
When I was putting it on I thought to myself why doesnt this thing have fasteners at the bottom because I thought it might leak.I checked and edelbrocks two piece does have fasteners at the bottom . I am going to pull this thing back off and drill it to fasten the bottom.
Old 12-12-2004, 06:21 PM
lluciano77's Avatar
Don't you wish Chevy would have designed their oil pans to attach to the timing covers like Ford did? I sure do. My 5.0 has never leaked.
Old 12-12-2004, 06:28 PM
Max Keith's Avatar
Having never dealt with one of those covers, is there enough room to possibly drill a couple holes and put a couple short sheet metal screws in it?
Old 12-12-2004, 06:31 PM
lluciano77's Avatar
You would have to get the screws to go into the block. That wouldn't be easy. I wouldn't try it. You could drill and tap a couple more holes at the bottom of the block as far down as you can go. That may help. The bulge happens in an area tha is kind of free floating though.
Old 12-12-2004, 06:35 PM
Max Keith's Avatar
As I said, Ive never messed with a 2 piece timing cover, so I thought I would just toss that out there.
Sounds like another job for Ultra Copper or some such silicon stuff.
Old 12-13-2004, 12:32 PM
nabx22's Avatar
I have fixed this cover by taking it back off and drilling it at the bottom for three screws .You do not have to drill the block just both halves of the cover then install sheetmetal screws at the bottom tighten the three small screws at the bottom before tightening the rest of the cover.I dont know why Mr.Gasket didnt design it this way to begin with.Just wanted to let you know it could be done in case anybody else has this problem.
Old 12-13-2004, 12:54 PM
my350camaro84's Avatar
Smoke Tires, Not Drugs.
hmm I just bought an engine dress-up kit from Mr. Gasket for my small block and it came with a 1 piece timing cover that fits fine. just thought I'd let ya guys know :-D
Old 12-13-2004, 02:41 PM
Max Keith's Avatar
I am curious as to the benefits of running a two piece timing cover. I have seen them in parts catalogues forever, but none of the Stovebolt (Bow Tie) guys I know ever used them.
Old 12-13-2004, 04:09 PM
oldsgeek's Avatar
81 olds cutlass, 350 chevy
Last journal entry: out with the old , in with the new !
to change the cam....
Old 12-13-2004, 04:17 PM
Max Keith's Avatar
two piece
Gotcha, without having to remove the harmonic balancer and all that. Kind of thought that may be what it was but wasnt sure.
Sounds like the perfect setup for the guy that cant decide what cam to run.
Could definately be handy if you are racing stock cars on a variety of track types.
Like my wife; should I wear the blue dress, the red one, or the black one. LOL.
Old 12-13-2004, 04:18 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Re: two piece timing cover
Unless you're swapping cams frequently the extra cost of a two piece timing cover isn't justified, which is why most people don't use them.
Mr. Gasket products are only so-so on their quality level, glad you got your leak fixed.
Old 12-13-2004, 04:22 PM
Max Keith's Avatar
two piece cover
Could it be a status thing like chrome rocker covers?
