Mr. Streetrodder - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 01-23-2006, 12:59 PM
Mr. Streetrodder
I've got two streetrods, a 1934 chevy cp. 3 window with a rumble seat. Original steel body car. 327 engine, mustang ll frontend, tubular a-arms, rack and pinion steering, 350 turbo trans w/stall convertor, 79 Lincoln rear(9inch)with 350 gears and a (28spline spool with 411's). My other car is a 37 Dodge 4dr. sedan, mustang ll frontend with 11inch disc brakes, rack and pinion steering, C.A.R. custom radiator, a 1965, 413 wedge engine. lot's of extras, a 1966 dodge coronet rear, 8 3/4 suregrip w/3:23 gears. The paint is Dupont tophalf is purple, bottom is black. Interior is finished too. Mopar rallies with chrome rings.
The chevy occasionally gets raced. best so far is a pair of 12.67s @ 104mph street tires, through the mufflers, in drive. I can do better. This year I've added edelbrock performer aluminum heads, performer RPM airgap intake, new 11-1 pistons, a 650 Demon carb, comp engineering ladderbars. electric water pump. Ready for spring!
Name:	34 coupe.JPG
Old 01-23-2006, 01:20 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to the Hotrodders Bulletin Board, hope you enjoy the site.
Old 01-23-2006, 02:11 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
WELCOME TO HOTRODDERS.COM
The most innovative Site on the Net
Thanks for joining
"SlowRide66"
"Illegitimis non carborundum"
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 04:36 PM
Mr Mutt Jim Kennard Introduce Yourself 2 10-27-2005 04:30 AM
scam the scamers akm Hotrodders' Lounge 19 10-12-2004 10:16 PM
Mr Gasket breathers andybird Engine 2 04-03-2003 02:09 AM
