Msd 2 step installation? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2010, 03:41 AM
Does anyone know how to install the msd 2 step without using a msd ignition box? This is what I have:
http://www.summitracing.com/parts/MSD-8739
I have an HEI distributor. Im just looking for a cheap rev limiter and I have this lying around. I understand it needs a power and ground, but where would I run the little 2 prong cord? Im really confused as to how I would hook it to the actual ignition. Thanks.
Old 10-30-2010, 04:58 AM
ericnova72's Avatar
More for Less Racer
The Two Step is not a rev limiter itself, it is only a electronic selector between two different limit chips. You can't use it with the stock HEI, the Two Step box plugs into the rpm chip port on a MSD box like the 6AL or 7AL, etc. The Two Step is used to provide a burnout rpm limit or a starting line rev limit (by hooking to Trans brake switch, clutch pedal switch, or line lock switch), and a second rpm limiter for normal engine operational top end limit.
The only product MSD has to limit rpm on a stock type HEI is the Soft Touch Rev Control, Part # 8728.
Online Step by step photo help. Halloweenking Body - Exterior 9 12-12-2004 09:04 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
MSD ignition problems PDSTEVE Electrical 2 03-28-2003 05:33 AM
step by step! Chucks,57 Hotrodders' Lounge 3 03-16-2003 07:38 AM
Rebuilding my first Q-jet carb and need step by step. MopaRV Engine 8 12-31-2002 03:41 PM
