MSD 6A all that? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2005, 09:03 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
MSD 6A all that?
Is there a noticable difference (fuel milage/horse power) between running a MSD multiple spark ignition like the 6A and not running one? Does anybody have any 1/4 mile ETs to compare before and after the MSD?
How does the Mallory multiple spark ignition compare to the MSD? The Mallory is a good chunk of change cheaper.
Old 03-12-2005, 09:09 PM
lluciano77's Avatar
I think the Digital 6s are good. They are pretty expensive.
I did a bunch of research before I bought my ignition. I found that the Crane HI6 puts out more spark and is overall the best for the price. They are around $200. The have better components than MSD, and have a rev limiter that doesn't need pills. Also. there is a tach test feature that is nice to have. They have a self diagnostic that helps kee[ them from frying and tells you what may be wrong.
Spark boxes clean up your idle/cruise significantly below 3,000 RPMs.
Old 03-12-2005, 11:37 PM
If you have a stock motor it's not going to do anything for you. An upgraded HEI, module and coil, will work just as well, even up to 450 HP.
Old 03-13-2005, 02:06 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Pricing
The Crane box has compatibility issues with the MSD distributors. You get what you pay for!
Old 03-13-2005, 10:46 AM
70bird's Avatar
Is the compatibility issue with the MSD module. I just picked up MSD HEI distributor kit (module, coil, cap, rotor dust cover).
Old 03-13-2005, 11:50 AM
lluciano77's Avatar
The HI6 is compatible with MSD distributors.
You read it wrong. In the Crane instructions it says that the HI6 isn't compatible with MSD ignition boxes. Why would you run both at the same time anyway?
HI6 instructions
Old 03-13-2005, 01:02 PM
bracketeer's Avatar
489 Lemans
MSD vs Crane
I had a Crane box with an MSD distributor. The carb would explode and catch fire at 4000 rpm. I called Crane and they told me that they were aware of the problem and return the box. I bought an MSD 6A and never had any ignition problems. But the MSD box would not work with my stock 3 wire tach. I had to buy an autometer tach.
Old 03-13-2005, 01:23 PM
spinn's Avatar
i run a msd 6 al and have never looked back.the limiter works well,all adjustments are easy. very durable piece.
the stock GM hei is a good piece also,with factory reliablility(factory has quality pieces). i dont think any gains can be realized, unless your at a ultra high performance level with high compression and turbulent mixtures.
why ,cause both lite the fire just fine.
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
MSD box questions? HemmiGremmie Electrical 3 05-29-2003 01:46 AM
MSD 6A bigjoedo Engine 2 11-19-2002 05:18 PM
Where to install MSD 6A on 76 Vette??? FredT Engine 0 10-09-2002 04:17 PM
