MSD 6a to GM Hei - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2010, 01:56 PM
UngerMarkus's Avatar
Tuck´n´Roller
MSD 6a to GM Hei
Hi guys!
Today I got myselfe a MSD 6a unit to upgrade the stock GM Hei ignition I run in my modified 69´ 400cui Pontiac.
Will the ignition box alone be any good, or do I have to upgrade to a different coil/cap as well?
Markus
Old 08-05-2010, 02:14 PM
bubbahotep's Avatar
It'll work but a new higher output coil would be complete.
Old 08-05-2010, 02:47 PM
malc's Avatar
Living At The Speed Of Life
Here are the MSD Instructions scroll down for the box to HEI wiring diagram.
You´ll need the MSD harnesses MSD-8861 and MSD-8860.
Old 08-15-2010, 01:02 PM
Tuck´n´Roller
Hi folks!
I recently installed the MSD 6a. Idle became a little better and somehow, the engine not just sounds a lot more powerful, it even helped to get the big old lady off the line a little quicker! BUT a new problem occured! The engine now starts pinging at WOT (~3500rpm) or on a hill. When I accelerate at about 3/4 throttle and on a level road it´s fine.
I filled her up with premium gas plus lead substitude. Now the pinging is gone, but I lost a lot of performance. How can that be?
With "Plus" gas, my Pontiac used to smoked the tires as long as i put the throttle down. Now it doesn´t even squeak a little.
Does anybody have an idea how this can be?
Help with MSD 6A! bowtietillidieSS Electrical 8 05-29-2010 04:54 PM
Timing Light with MSD 6a box nawlins-tim Engine 2 05-05-2010 09:42 PM
Accel points conversion to MSD 6A Box ChevPuba Electrical 3 07-27-2007 03:23 PM
MSD 6A all that? 70bird Engine 7 03-13-2005 02:23 PM
When is MSD6AL better than GM HEI? shockers69 Engine 0 12-29-2003 04:14 PM
