msd 6a wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2007, 05:42 PM
msd 6a wiring
msd 6a wiring i have an 70s model gm hei bought a used msd 6a box
. have read that it needs a wiring harness but could i cut the harness plug and wire into the dist . i know harness is only 7.00 but i do not know if the msd box is any good .
thanks
Old 02-22-2007, 06:05 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
thanks
It would be worth $ 7 to me not to cut, solder, and heat shrink the distributor wires, and then be hard-wired-in.
At least if it broke later you could just unplug it and go on.
Old 02-23-2007, 03:42 AM
Wiki Edits: 31
I'V heard MSD will fix any broken MSD box for $35.
Old 02-23-2007, 06:11 AM
msd 6 series to gm hei
GM used 4 5 and 7 pin modules in the HEI distributors. Only the 4 pin module uses the magnetic pickup connector from the box in which case they recommend pn 8860 harness to the distributor and pn 8861 which goes into the distributor and replaces the GM module. If you have a 5 or 7 pin module the magnetic pickup connector is not used. I see no reason to cut the plug off. My brother-in-law sent his 6al box back this year. It was fixed, recalibrated and overnighted back to him for eighty-some dollars but again it was overnight delivery.
Old 02-23-2007, 11:59 AM
johnsongrass1's Avatar
Race it, Don't rice it!
MSD cahrges between 35min to 75max dollars no matter what's wrong. Even if nothing is wrong. I had a box just burned for 8 hours straight trying to find a intermitten problem. Still haven't found it.
msd 6200 6a vicvero69 Introduce Yourself 1 12-17-2006 06:19 PM
MSD 6A Is it the Problem? nova69 Electrical 6 12-10-2006 07:41 PM
Wiring A Complete Msd System TROLLMAN Electrical 11 05-17-2006 02:23 PM
MSD 6A all that? 70bird Engine 7 03-13-2005 01:23 PM
MSD 6A bigjoedo Engine 2 11-19-2002 05:18 PM
