Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MSD 6a wiring
Thread: MSD 6a wiring
Old 10-22-2010, 10:26 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
You have it wired wrong, as per the installation PDF page 23 shows the white points trigger wire hooked to the black from the Pertrontic's Ignitor, the small Red is connected to the Red from the Pertronic's and together these two Reds are connected to the Red 12v+from the ignition switch.
You don't use the magnetic trigger green/violet according to the instructions. Wired much like a points system.
