Msd 6al - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2004, 06:08 PM
Msd 6al
Has anyone experienced a problem with the MSD box what happens is the vehicle runs fine while normal driving but as soon as you turn on the headlights I get extremely bright lights and then all of a sudden they go dim and the MSD box is fried I have a new alternator that I had tested and it puts out close to 80 amps a new battery and a fairly new voltage regulator in place when I place a meter on the battery with the ignitioin running the battery shows 15.2 volts I dont know what else to do?? Any suggestions would be greatly appreciated I also have the MSD box on a toggle switch but it is connected the hot side of the fuse block.
Old 03-05-2004, 03:01 PM
Ian70Mustang's Avatar
New Member
sounds to me like a voltage regulator. double check that, maybe replace it.
Old 03-06-2004, 05:52 PM
roys63's Avatar
check all your grounds and the regulator ground to alt all so .
Old 03-07-2004, 09:57 AM
New Member
Did you just put the MSD box in ?
Or has it been in for a while ?
