Msd 6btm - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2014, 12:42 PM
Fang16's Avatar
Last journal entry: Project change
Msd 6btm
Running a blown 350 in a 52 Henry J. New build, mostly old stuff. It has a MSD dist and a 6BTM box, timing set at 30* at 2600. Problem is it goes on what sounds like a rev limiter at 4800, even with BTM knob disconnected. Running two Holly 780 double pumpers at 6 lbs. Engine dynoed at 566 hp on engine dyno. 6000 RPM pill checks out correctly on an ohm meter.
Old 07-25-2014, 02:17 PM
Banned
does the box think it's hook to a 6 instead of an 8..
Old 07-25-2014, 02:39 PM
Banned
mmmmmmmmmmmmmmmmmmmmmmmmm
ID:	163073   Click image for larger version
ID:	163081   Click image for larger version
ID:	163089   Click image for larger version
Old 07-25-2014, 02:42 PM
Banned
mmmmmmmmmmmmmmm2
ID:	163105   Click image for larger version
Old 07-25-2014, 02:49 PM
Banned
I have the whole msd disc.. so.. if you need more..
Old 07-25-2014, 07:23 PM
spinn's Avatar
Take it out, no leave the limiting chip in.
Idiot proof it.
Old 07-26-2014, 06:12 AM
BOBCRMAN@aol.com's Avatar
Just recently had a simular problem with a MSD unit and it turned out to be the unit was receiving less than 12 volts.
MSD 6BTM or 6AL-2 Programmable jkkrs310 Engine 2 11-20-2012 10:58 AM
Ignition wires MSD or f.e. ACCEL to MSD pro-billet & digital-6?? Berres Electrical 4 11-27-2009 01:17 PM
Question about hooking a msd blaster coil to a msd dizzy tiresmoke55 Engine 4 04-29-2008 03:41 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
MSD 7AL vs Msd digital 6 in a race car? mr_chickenhead Engine 9 12-08-2003 10:04 PM
