MSD 6BTM or 6AL-2 Programmable - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2012, 08:59 AM
I just added a 6 71 Weiand blower to my 383 SBC and wanted to ask which ignition box I should go with.
I have a truck mounted Alcohol Injection System (AIS). A key piece of information is my compression is a little high at 9.8 but I don't plan to race the car as it is just a street cruiser. I only plan to run ~5lbs of boost. The blower will be under-driven at -10.5.
I currently have the 6AL-2 Programmable which will allow me to lock out the dist and set the timing curve from a laptop and also pull timing out per lbs boost. The 6BTM has a dial to manually adjust how much timing to remove per lbs of boost.
My question: What box does everyone recommend for my application and why? I searched the site but can't get a clear asnwer so thought I'd try and get first hand expeience and input.
Thanks in advance.
Old 11-20-2012, 09:42 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I'm not familiar with an AL-2 program, and wonder how does is pull timing without a boost reference line from the manifold?
I run a BTM on my 8-71 383. When it was sent to El Paso for repairs I bought a 6-AL, went to the strip for test and tune, with conservative timing and running rich, three runs later if nosed over at 1,000 feet, burned 5 pistons. They were hammered so bad I couldn't pull the rings from the grooves, and of course I couldn't hear it happening. I hope that programmable unit does what you say, it was an expensive day for me thinking I was good to go. I've since installed an injection system as well.
Semper Fi
Old 11-20-2012, 10:58 AM
You bring up a good point. I guess I'm safer just setting the timing and using the BTM to pull it out.
programmable 6AL-2 OR NOT ? crystalbluevib Electrical 1 01-18-2010 06:50 PM
MSD 6AL-2 programmable gonna_be_fast78 Electrical 2 12-25-2009 05:24 AM
MSD 6AL-2 Programmable Ignition T fortwo Engine 6 12-09-2009 05:41 AM
Msd 6al Eagle1 Engine 3 08-12-2004 01:03 PM
MSD 6AL Help airman_turtle Electrical 2 07-06-2004 10:43 PM
