MSD 8365 HEI, no spark after setting rev limiter - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2005, 05:45 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I was reading another post in regards to the MSD 8394 E-Curve. http://www.hotrodders.com/showthread.php?t=66113 They guy had to jump his car everytime he tried to start it after installing this dist.
I purchased an MSD 8365 HEI. Mine worked fine until I adjusted the rev limiter. Now it has no spark. I have 12.3 volts at coil and 10.2 at coil while cranking. Anyone else have the same problems with either of these distributors?
Old 07-23-2005, 11:01 AM
speedfreak2's Avatar
WrenchingAce
Just curious, but where did you set the rev limiter at?
Old 07-23-2005, 08:11 PM
bracketeer's Avatar
489 Lemans
I moved from 8000 rpm down to 7000 rpm. It is adjustable between 10,000 and 5000.
Old 07-23-2005, 10:56 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
10.2 volts sounds too low to get a spark. What is the voltage across the battery when cranking? If it's also 10.2 than you just had the unfortunate coincidence of a battery dying at the same time you adjusted your limiter. Easy to check by jumping or putting a fully charged battery in and see if it starts.
If you have 11.5-12v across the battery then you have a wiring issue somewhere. I'd check the wiring and perhaps install a relay driven by the ignition switch so you can get 12v straight from the battery.
Old 07-23-2005, 11:21 PM
bracketeer's Avatar
489 Lemans
Battery is new. 3 days old. fully charged. The power to the dist is 12.2 in on position. 10.3 in crank position. Before I reset rev limiter. 13.4 volts at dist running.
I feel there is a problem with these adjustable distributors and MSD isn't admitting to it. So I wanted to see how many ppl on here have had problems with them. They are new to the market. I was on a waiting list to get one.
The only other person I have found who has used one is having problems too.
Old 08-13-2006, 08:55 PM
Buscop's Avatar
I just had the same problem with my MSD 8365 at a car cruise with my '79 Monza's 355 SBC. Got there and then wouldn't start. No spark at the plugs. Towed her home and put in the stock HEI and no problem starting. Going to take the MSD back and ask for another one. Maybe its a bad batch and we'll see if another one works. Stay tuned.
Old 08-13-2006, 11:51 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
After reading the instructions for that rev limiter, It says in the Text that small increment movements make big RPM changes (Eluding to the 5 to 10 index may not be CLOSE to accurate..)
Try going BACK to the start point and see if you regain spark, and if so..you may need to hand tach the limit..while turning the preset CCW in Very small increments..
In other words, the limiter MAY be out of Fire range right now..
Just a logical guess..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-14-2006, 06:43 AM
35chev/302gmc's Avatar
Check out the MSD web site, they have a tech forum.
1935 chevy,masters
Old 08-14-2006, 07:37 PM
Buscop's Avatar
Been there and its not that helpful.....it takes them days to reply if at all.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
MSD rev limiter johnsongrass1 Hotrodders' Lounge 1 06-29-2005 06:35 PM
MSD 6AL rev limiter strokercuda Electrical 1 12-01-2004 01:08 PM
Rev Limiter and CD ignition setups. Croz Electrical 0 04-01-2004 09:33 PM
upgrade hei or go all msd Super Chevy Electrical 9 01-30-2004 12:59 PM
