MSD 8963 Shift Light - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2006, 08:14 PM
Steve karch's Avatar
I just bought a MSD 8963 Digital LED Shift Light. It has a GMR and the instructions show just about every ign but HEI which is what I am using. Anyone familar with this shift light and if so I need help with the install such as what do I hook the GMR to. Will a 12 volt source work or primary (+) coil.
Old 06-21-2006, 06:33 AM
Technical Support Barry Grant
The 8693 is extremely simple, it only has three wires, Red, Green, and Black.
Wire up as follows:
Red goes to a keyed on or switched on 12 volt source. Meaning this is only hot when the ignition is on.
Black goes to a good engine ground.
Green goes to your tach output.
Old 06-21-2006, 05:31 PM
Thanks BG Tech. But what about the GMR. Thats where my little manager brain gets confused. Do I need that or not.
Steve
Old 06-21-2006, 08:21 PM
Never mind. I installed it as you said and works ok. Very easy
Old 06-22-2006, 06:20 AM
Glad to help.
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 10:02 PM
th400 2-3 shift?? camaroman7d Transmission - Rearend 6 04-22-2004 01:06 AM
slight clunk/ shift kit install Q's HARVICKx29 Transmission - Rearend 2 02-16-2004 09:51 PM
transmission shift too early? CurtisL Transmission - Rearend 4 11-05-2003 11:41 AM
TH-350, low rpm 1/2 shift gearhead_383 Transmission - Rearend 7 10-30-2003 08:52 AM
