MSD Box - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2013, 07:56 AM
Mac88's Avatar
"Drive It Until It Breaks"
MSD Box
I have a 88 Mustang GT that I convert to carb, running with a MSD 6AL box. I also put on a after market distributor. I'm about to sell the Mustang but keeping the MSD box for another project, and I'm looking for a ICM to replace the box with. The car came with the ICM that plugged into the distributor, but since I changed the distributor, will any fender mounted ICM work?
Old 01-20-2013, 12:35 PM
LATECH's Avatar
Just rig up the old Dura spark II system on it. As long as you have a mechanical/vacuum advance and a magnetic pickup in the dizzy you got.
Or just pull the whole thing from a U Pull It yard.
You can also run a GM 4 pin module on the duraspark dizzy
Fact is stranger than Fiction
Old 01-20-2013, 12:38 PM
LATECH's Avatar
http://www.junkyardgenius.com/ignition/jeep/HEI01/.html
Good stuff here.
Old 01-20-2013, 03:05 PM
Mac88's Avatar
Re
Thanks for the reply.
Old 01-20-2013, 05:13 PM
Mac88's Avatar
Ignition Module Wiring
I went and picked up a Dura Spark II box. Not sure exactly sure which wires go to what. The three wires coming off my distributor are Red/Black, Purple/Black, and Black. The wires coming from the ignition module are split into two plugs. One plug has two wires, 1 x white and 1 x red. The second plug has four wires, 1x orange, 1 x purple, 1 x black, and 1 x green. Can someone give me breakdown on where each wire goes?
ID:	70751   Click image for larger version
Old 01-20-2013, 07:52 PM
LATECH's Avatar
Here is a color schematic.
your car was allready electronic. Just be sure the white goes to the I terminal at the solenoid (hot when cranking starter) and the red goes to hot in run.
I see the link I posted didnt work.
The Following User Says Thank You to LATECH For This Useful Post:
fwinter01 (02-14-2013)
Old 01-20-2013, 07:58 PM
LATECH's Avatar
The plain black should be ground. Verify it with an ohm meter. Then hook it to black on the module.
Red balck and purple black go to the other 2 wires at the dizzy.
Purple to purple black would make sense, then red black to orange.
If it ends up that they are backwards it wont hurt anything, it may just not run.
The four pin connector , you will need only a hot in run and start. Hook it to the red wire at the module. If you want the white wire to retard spark timing (which is what it does) then hook it to the wire in the 4 pin connector that is 12 v + while cranking, as pictured in the schematic.
Whoops...green wire from module goes to coil -
Old 01-20-2013, 08:10 PM
LATECH's Avatar
Last edited by LATECH; 01-20-2013 at 08:21 PM. Reason: uneccesary/confusing info..disregard
Old 01-21-2013, 03:08 PM
Mac88's Avatar
Re
Thanks, changed it out and car fired right up.
Old 01-21-2013, 05:33 PM
LATECH's Avatar
Sweet........
Old 02-14-2013, 06:38 PM
is this a msd 6200 series box? or dura spark box
MSD digital 6A box? 327NUT Electrical 1 10-09-2012 06:28 AM
msd 6al box stinger460 Electrical 1 08-18-2011 11:11 AM
Msd box V305 Electrical 1 12-15-2008 06:14 AM
Installing MSD Box redial Electrical 4 12-22-2005 10:10 AM
MSD box questions? HemmiGremmie Electrical 3 05-29-2003 02:46 AM
