msd coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2009, 05:51 PM
msd coil
i just installed the 6al system with the blaster 2 coil. this is the first experience ive hade with an external coil because ive always had hei systems. i have everything wired. the only question i have is about the coil. it came in pieces. the coil, the coil tower, long screw, coiled wire washer, and the spark plug end piece. the directions dont say how to put the coil tower together. most people probably just know how but i dont. i tried puting it together but it fits loosley in the coil. if anyone has experience with this any help would be great thanks
Old 04-15-2009, 06:00 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
is this what you have.http://cgi.ebay.com/ebaymotors/MSD-8...QQcmdZViewItem . cole
Old 04-15-2009, 06:12 PM
coil
no that is the bracket im talking about the actual coil. here is a pic from summit that is similar to what i have. in the pic you see the coil. and then the small red coil tower beside it. that small tower is what i need to know how to put together. thanks
Old 04-15-2009, 06:43 PM
eloc431962's Avatar
Wiki Edits: 37
I left it off of mine.all that does is help prevent secondary voltage from jumping between the terminals.and sometimes it makes it a little easier to connect the coil wire.I would leave it off you really dont need it .and later if you feel you do then you can put it on,its really your call.all it does is pushes down on the top of the coil for a extinsion. cole
Old 04-15-2009, 07:14 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
That tower as you call it, allows you to use the hei ends on the coil wire. Are you aware that there are two different terminals that ignitions wires may use ?
There are two different types of terminal ends , with that tower it allows the use of the newer style terminal ends HEI. Not using the tower, for simplicity lets just call them old school terminals, can be used .
If you buy a set of plug wires, the universal set, you will see the two type of terminals shipped in the package .
Old 04-15-2009, 08:48 PM
eloc431962's Avatar
Wiki Edits: 37
yea thanks pepi, I totaly forgot about the two different wire ends. . cole
Old 04-15-2009, 11:25 PM
msd-8500
well im still runing the hei system just with an external coil. i ordered the kit from summit msd-8500 and all of the stuff came with it. it says to use that red coil tower i just cant figure it out.
Old 04-16-2009, 12:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The tower is used to convert a coil w/the "old" style female wire connection to the "newer" male HEI-style connector.
If your coil already has the male connector OR if you are using a coil wire that connects to the female-type coil connector- you do not need to use it.
Old 04-16-2009, 12:17 AM
hi, trash the ballast resistor. if you are running HEI wires (coil wire)use the tower. the 2 boots are for either an HEI or a standard/early coil wire. whichever one you have.
darn you cobalt--beat me to it by a minute...
Old 04-16-2009, 12:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You know what they say- even a blind pig finds an acorn once in a while! lol
Old 04-16-2009, 01:55 AM
hey colbalt, 800+ posts, and you are a noob. i only have 600+ posts since 2007. but then i spend much time restoring old vettes out here in cal. you seem very knowledgable from your posts in EVERY thread. fill out your profile, all the noobs don't fill out their profiles, tell us how old you are and tell us about your cars and profession. please don't take this the wrong way. i just want to know how how much you know, seems like a lot from your posts (but not as much as i know) no offence, i like you...
Old 04-16-2009, 06:12 AM
ok
yea i know i have to use the hei tower. but thats still my question, how to i put it together. lol that little red tower in the pic comes in 4 pieces.
Old 04-16-2009, 07:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm a post whore- what can I say. Had a knee 'scoped so have time to waste.
As for you knowing more, may be true, maybe not- but I have sense enough to know there are people here who know more than either of us, so it's all relative, isn't it?.
And I did just get the cam/crank relationship backwards- even though I know the difference, so there you go... F-ups go w/the territory. Admitting them is the hard part.
Old 04-16-2009, 08:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Without having it in my hands, I can't say- the only one I ever saw came assembled from MSD.
I'd be on the blower to their tech line if it were me.
Old 04-16-2009, 08:11 AM
pepi's Avatar
are you sure 4 pieces? does that mean 2 boots , the tower, and the resister ........ if this is so you are not using plain old common sense .
very simple plug the tower into the top of the coil mount on firewall and attach the coil wire ........... is that simple enough to figure out... ?
GM / MSD coil wired backwards? Possible? bubbahotep Electrical 23 03-28-2009 07:45 PM
Question about hooking a msd blaster coil to a msd dizzy tiresmoke55 Engine 4 04-29-2008 04:41 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
MSD coil testing joe350s10 Electrical 14 02-16-2006 11:35 AM
Mallory coil vs. MSD Blaster 2 McDeuce Electrical 10 02-29-2004 08:57 PM
