Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MSD coil
Thread: MSD coil
Old 08-19-2004, 11:53 PM
lluciano77's Avatar
lluciano77 lluciano77 is offline
The voltage stays the same on the primay side of the coil. 12-14V
A volt meter does not tell you much at all about your charging system. That is what an ammeter is for.
The new coil is drawing more amperage. You may need a higher amperage rated alternator. Or, maybe the one you have isn;t charging where it should be. A dead cell in the bettery could also cause ampacity loss.
