Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is a MSD coil bad if it leaks oil?
Old 07-21-2005, 05:34 PM
commando57 commando57 is offline
MSD chrome coil, leaks oil from where you plug in the coil wire, is this ok?
Should it have 12 volts to it or a resistor? There are no points. All MSD stuff,
Vette tach drive distributor and 6AL box. Should I send the coil back?
What should I do?
