Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is a MSD coil bad if it leaks oil?
Old 07-21-2005, 06:23 PM
Zimmo's Avatar
Zimmo Zimmo is offline
If it's leaking oil it will overheat & short out the rest of the system (Box & all)
If it's in a vette & it's mounted at an angle, do not use a reg oil filled coil with an MSD (An air bubble will be where oil should be causing on ovht)
Install a high vibration (Epoxy filled) coil
