Is a MSD coil bad if it leaks oil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2005, 06:34 PM
MSD chrome coil, leaks oil from where you plug in the coil wire, is this ok?
Should it have 12 volts to it or a resistor? There are no points. All MSD stuff,
Vette tach drive distributor and 6AL box. Should I send the coil back?
What should I do?
Old 07-21-2005, 07:09 PM
sedan delivery's Avatar
coil leak
i can only answer part of your question. oil should not leak from any coil. if it new let them know . they may want it sent back.
Old 07-21-2005, 07:23 PM
Zimmo's Avatar
If it's leaking oil it will overheat & short out the rest of the system (Box & all)
If it's in a vette & it's mounted at an angle, do not use a reg oil filled coil with an MSD (An air bubble will be where oil should be causing on ovht)
Install a high vibration (Epoxy filled) coil
Old 07-21-2005, 07:25 PM
Last journal entry: PICTURE TEST
coil
Get rid of it... It's shot
keith
Old 07-21-2005, 07:29 PM
Jmark's Avatar
Send it to me, I like to wire them to 220 and watch them blow!
Old 07-21-2005, 09:40 PM
97Z28's Avatar
NTI Grad.
hmm... wire it up to a 220 line? and it really explodes? how exactly do you do that?
Old 07-21-2005, 09:45 PM
Bumpstick's Avatar
Hammer and a torch
Very carefully.....!
Old 07-21-2005, 09:47 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
how big is the explosion? We should send a box of em and instructions on how to wire them to 220 to the terrorists. They'd blow themselves up "testing" them.
wow, an easy solution. now let's get the job done and bring our boys home.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
MSD coil mitmaks Engine 3 08-20-2004 01:08 AM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 06:17 AM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
High Volume Oil Pump (Good or Bad) ? white66coupe Engine 5 11-05-2002 04:27 PM
