MSD Coil and Coil Wire Question
I just bought a complete MSD system (6AL, Blaster 2 coil, Pro-Billet distributor, 8.5mm wires).
I also purchased the 84039 coil wire kit to use with my Blaster 2 coil. The wire does not fit the coil directly. The coil wire kit came with a terminal adapter post, apparently to adapt the HEI wire they put in the kit to the coil. The whole thing looks like a bad idea. The adapter is not going to stay on the coil unless I tape it on there. Even then I'm not so sure it would make contact with the terminal inside of the coil. Is there something I am missing here??? I'm not sure why they did this since the kit is specifically for the Blaster 2 coil, so you would think that they would give the correct wire instead of an adapter. Like I said; maybe I am missing something. I plan on buying a coil boot and terminal to make it work like MSD should have done in the first place, but I really want to get this thing runnig in the mean time. |
I found this statement on another forum that the guy was having the same problem. A guy at a local shop here, told me that you're supposed to put the power tower adapter on the coil, THEN turn the top terminal and it will tighten and get snug.
Part of the idea behind using it is to prevent any arcing caused by the increased output. Whether that's really needed, I cannot say; I used the post and had no probs, though. Found this at Chevy High Performance mag: http://www.crankshaftcoalition.com/w..._tower_msd.jpg "This Power Tower adapter comes with the modified dustcover and coil wire portion of the Super HEI Kit. To attach it, the socket-type plug end is unscrewed and the adapter is placed into the female-style plug opening on the coil. The plug end is then tightened, which expands the inside of the adapter against the coil opening, holding it in place." Interestingly, I thought I remembered there being instructions included for installing/tightening it, but the MSD forum has several questions on how to install it and the tech there said to just install it like any HEI plug wire. Which we know is wrong...:smash: Power tower adapter install instructions [Archive] - MSD Tech Support Forums |
Thanks for the help.
I went out to the garage and attempted to install it. No matter how tight I tightened it, it still pops off very easily. Not to mention that the "tighter" you make the screw the further away from the actual terminal it gets. I can't imagine that's going to help things any. The whole idea is just gay. I think I can say that in this forum and I can't think of anyway else to say it. I went down to the local parts store and managed to find an actual coil wire that I will use until I have a chance to order a boot for the wire I got with the kit. Again, thanks for the help. My next step was to call MSD about it, but that's would have just ended with me whining more about it and telling the techie what a horrible idea it was like that poor bastard had anything to do with it. |
Maybe something like this would work with your coil wire. MSD Ignition 8401 - MSD Modified HEI Dust Covers - Overview - SummitRacing.com
| All times are GMT -6. The time now is 06:33 AM. |
