Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MSD coil testing
Old 02-06-2006, 07:55 PM
joe350s10's Avatar
joe350s10 joe350s10 is offline
Bigger is better
Ok, an update....
tested the coil and it was bad. replaced the coil. (Went with an 8225 MSD)
Still no spark.
tested the module. Module was bad. replaced module.
fired right up. i also put die-electric grease on all of the connectors...just in case.
took it for a test run...
now the damned vacuum advance isn't working properly...but while changing the module I noticed the mechanical weights weren't in great shape. probably stuck closed.
So... I guess I'll upgrade the weights, get a new cap and pickup this weekend. Hell, I figure if I replaced half of it, mine as well go all the way!
Thanks for the info guys. i really appreciate it. once I actually thought about how the coil and module work, i figured out how to test them properly. big DUH on my part.
First time I have ever seen a coild AND a module go bad together.
Guess there is a first time for eveything.
