MSD distributor/2300 autogage tach - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2005, 02:22 PM
New Member
I can't get my 2300 autogage tach to work with my new MSD (hei) distributor (PN8365). Tried connecting it to the tach terminal provided at the distributor but I get nothing. Is there another way to wire it, an adapter, or are there tachs that will work with this distributor? It worked fine with the old points style distributor I had before and was connected to the positive side of the coil. Anyone have an idea or have ran across this problem in the past?
Old 08-29-2005, 04:41 PM
larryblack's Avatar
Certified Lead Foot
Usually Auto Meter tachs work from tach ports. Do you have to hook up power and ground too?
I suggest you go to Auto Meter's web site, contact their tech support and ask them. Or go to MSD's web and ask them.
Old 08-30-2005, 12:22 PM
Certian tachs need an adapter to work off msd stuff. The tech line can tell you if thats the case here, or if your wiring is missing something.
Old 08-30-2005, 01:36 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
The 8365 has a low output tachwire coming out of the body and a high output tach connection on the cap. Points style tachs using the digital spark boxes require MSD tach adapters. The tach signal is a square wave signal and has to be changed. I would say, since it doesn't work on the high output signal, it would require the tach adapter.
Sun Tach 383vette Electrical 6 12-30-2011 03:21 PM
Sun Tach. Wiring Help 383vette Electrical 4 10-02-2004 03:00 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 03:16 PM
No Spak MSD 6AL Setup 402 BBC Pinsky Electrical 2 08-22-2004 08:28 AM
mustang tach wiring stang_steve Electrical 0 07-14-2004 08:28 PM
