maintains oil pressure.
and directs oil to distributor shaft. http://www.chevytalk.org/fusionbb/sh...hp?tid/192284/ |
Just wondering what is the origin of this word dizzy for a distributor. I have never heard it before until reading it around this site and do not here it in the field. Seems to be some local HTBB term, it just sounds lame as a part id.
Can't you just here Austin Coil saying, "hay pass me the two dizzies and we can fire this thing" or is this one of those Hottroders terms, dumbing it down, like Hotrodders terms for dummies kind of thing. Maybe a pole here.. |
I actually picked it up here too....lol....too lazy to type distributor all of the time......I guess the question is why would you go out of your way to chamfer the distributor holes in the block just to run the o-rings and if the block was chamfered and you didnt use the o-rings what would happen and if there is any advantage to either?
The wear pattern should resemble the pattern on a differential ring & pinion, centered on the distributor gear & not eating in to the gear. If it's not centered you may need to shim it. I just apply plenty of assembly lube and start it up.
If your question is why is it necessary to chamfer the block, it's so you can get the distributor into the block with the o-rings in place. Without the chamfer, the o-rings get bound up and cut by the sharp edge of the block.
I've not ever seen the ring & pinion wear pattern, either, sorry! My distributor's gear wear is centered on the gear - and as far as eating the gear I guess that you mean taking metal away from the gear? Mine isn't doing that. |
dizzy, noss, donk, bubble, hopper, zip, etc.
a lot of new buzz words created by the younger generation to sound cool. Didn't you see the modern classic, Fast and Furious? It will be (IS) their American Grafitti and Two Lane Blacktop. Sort of like hot rod, rod, deuce, highboy, lead sled, etc. |
http://www.richmondgear.com/ringandpinion.pdf |
| Question about hooking a msd blaster coil to a msd dizzy | tiresmoke55 | Engine | 4 | 04-29-2008 03:41 PM |
| MSD dizzy chirping? | frankenvette | Engine | 13 | 12-29-2007 11:33 AM |
| Msd = Pain In *** !!! | Blackbob | Electrical | 4 | 02-21-2006 09:45 PM |
| MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU | izord | Electrical | 0 | 09-06-2004 02:16 PM |
| No Spak MSD 6AL Setup 402 BBC | Pinsky | Electrical | 2 | 08-22-2004 07:28 AM |
