Msd Hei - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 07:43 AM
bonsai's Avatar
Fill'er up!
Msd Hei
Changing to a MSD street fighter distributor and need to know how to determine the spark plug order on the cap. I have the wires marked but do not have them on the old cap for reference. New ditributor is in and just need to put the wires on the cap. HELP! SBC 350
Old 04-01-2012, 10:51 AM
V305's Avatar
On the Border
What I understand is that you changed your distributor and now you need to install the wires but you forgot the firing order?
the firing order of the sbc 350 is 1-8-4-3-6-5-7-2, the rotor spins clockwise so installing the wires on the cap goes the same way.
this link should help you Installing a Dist, it explains what you need to do
this can help too SBC firing order
Use the search bar in this forum, it helps a lot
Old 04-01-2012, 11:13 AM
bonsai's Avatar
Fill'er up!
So does it matter where you start on the cap for the #1 wire? I put a mark on the firewall and that is where the new rotor is pointing. Sorry for being such a newb!
Old 04-01-2012, 11:30 AM
bonsai's Avatar
Fill'er up!
Got it! Thanks V305!
Old 04-01-2012, 03:33 PM
V305's Avatar
On the Border
It really doesn't matter, you can start anywhere you want, just make sure the wires don't cross to prevent the sparks jumping from one wire to another
Old 04-04-2012, 11:59 AM
bonsai's Avatar
Fill'er up!
Do I need to install the vacuum advance stop plate if I'm only running a small rv cam? (Lunati Voodoo cam)
