Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MSD Hiccup with fan switch.
Old 11-13-2013, 07:48 AM
Denny Denny is offline
I give the same as I get...
((Iím guessing the voltage regulator canít keep up with the start load from the electric motors.))
Sounds more like a voltage drop. The load should be off the battery, thus the battery amperage. Do you have the loads separate, and not drawing from the same line ? Are the chassis grounds, also grounded good to the engine block ? Eng, Frame, Chassis.
