msd ignition question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2012, 09:21 PM
MSD ignition control boxes? opened it up no fuse to be found and no damage of burnt items. Called 800 number and followed there instruction and it's the box per there T/Sing instruction. Just looking for some one else experiences verses paying there dollars to send in. First build Be easy on the harsh feed backs
Old 07-19-2012, 09:53 PM
Greg T's Avatar
www.krusinklassics.net
Unless you have a complete schematic and the skills to diagnose and repair sophisticated electronics, you're pissing in the wind. Either send it in or replace it.
Old 07-20-2012, 08:02 AM
1971BB427's Avatar
Did a lot of electronics repair in the past, but I wont dig into an MSD box without something to determine what the component values are. Plus many components need to be removed from the board to test, and the heat from soldering and de-soldering will usually kill them or the printed board.
I'd check around on your local Craigslist. I see MSD boxes cheap all the time here. Just got one for my gasser locally for $40, and works great.
Old 07-20-2012, 09:28 AM
S10xGN's Avatar
Gotta love a turbo!
Newer MSD stuff is potted in epoxy and cannot be repaired. They usually test to see if it's their fault or the users and replace depending on warranty and fault...
Russ
ignition, msd
Ignition wires MSD or f.e. ACCEL to MSD pro-billet & digital-6?? Berres Electrical 4 11-27-2009 01:17 PM
Kwik wire kit and MSD ignition question. Help? BB72R-Yes Electrical 5 05-17-2009 10:09 AM
Question about hooking a msd blaster coil to a msd dizzy tiresmoke55 Engine 4 04-29-2008 03:41 PM
Quick Ignition Question- Digital tach MSD Pro Billet dist biggeazy-e Engine 2 06-03-2007 09:20 PM
MSD ignition question?? HemmiGremmie Engine 2 01-05-2006 08:25 AM
