msd ignition question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2012, 08:56 PM
I am getting ready to start my BBC ...I have a mad distributor with magnetic pickup and blaster 2 coil... and a ignition box... not my question is can I take the ignition box away and run the motor ... until I can afford another box...if so how do I wire it
Old 07-30-2012, 03:44 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
What's a mad distributor?
vicrod
Old 07-30-2012, 04:08 PM
Just do a search for MSD and call their tech line with the list of parts you have.
Old 07-31-2012, 05:41 AM
Irelands child's Avatar
If you have an MSD billet distributor, the installation instructions will tell you that you will need one of their boxes to run. Now, can those be bypassed and used as a conventional dist. - probably, with some wire and common sense, but why? It sounds like you have some bucks in the engine, and BBC's are never cheap, so spend your $200+ and get a new MSD box or send them your failed unit for rebuild for a few bucks less.
Irelands child
Old 07-31-2012, 06:23 AM
T-bucket23's Avatar
Wiki Edits: 26
It depends on what model distributor you have. If it has a module and pickup then yes it will work stand alone. If it only has a pickup then no it wont work. If you can supply model numbers it would be easier to help you.
Chet
msd ignition question fwinter01 Hotrodding Basics 3 07-20-2012 09:28 AM
Ignition wires MSD or f.e. ACCEL to MSD pro-billet & digital-6?? Berres Electrical 4 11-27-2009 01:17 PM
Kwik wire kit and MSD ignition question. Help? BB72R-Yes Electrical 5 05-17-2009 10:09 AM
Quick Ignition Question- Digital tach MSD Pro Billet dist biggeazy-e Engine 2 06-03-2007 09:20 PM
MSD ignition question?? HemmiGremmie Engine 2 01-05-2006 08:25 AM
