Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MSD Ignition questions
Old 11-24-2012, 09:51 PM
Greg T's Avatar
Greg T Greg T is offline
www.krusinklassics.net
Should have grounded the coil wire, NOT removed it. The excess gap caused a huge load on the box. The larger the gap the harder everything has to work. Ground the high tension lead to the fram or engine block when cranking.
