Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MSD Ignition questions
Old 11-25-2012, 09:48 AM
cdminter59 cdminter59 is offline
MSD Ignition Help!
Originally Posted by Aaronk227 View Post
It was only about a three second crank. There is no power going to the coil from the orange wire coming out of the MSD box, and when you try to crank it there is no spark from the coil. Any other troubleshooting ideas? Is there a way to bypass the box to see if the engine starts then?
Did you check the small red wire for 12+ volts? Is there a red LED light lit on the box with the key on? The small red wire should be going from the box to the ignition switch. It turns the box on and off. BTW what is the year, make, and model for the car? If it a newer car check the fuse box to see if ignition fuse is blown.
