Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - msd ingintion components
Old 02-06-2013, 08:18 AM
fwinter01 fwinter01 is offline
msd
Originally Posted by fwinter01 View Post
don't understand what I may of be doing incorrect, keep burning coils.
6200 series box with a marine non vacuum msd distributor, wired per instruction, use two wire clip that connects to the distributor and tied off the white wire with a cap. Vehicle is ground well cab, engine and battery neg is ground to frame with clean connection. Box is connected heavy red and black which are 10 ga directly to battery + and -. Motor runs for a while then dies coil is done. Engine is a stock crate 305 using msd ingintion components, charging system is on line at 13.5
