Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - msd ingintion components
Old 02-06-2013, 10:25 AM
33Willys77's Avatar
33Willys77 33Willys77 is offline
What type of plug wires? Orange wire from box to + on coil and small black to - on coil. Should need nothing more on the coil. Solid core wires can not be used with MSD. Are you sure the coil is going bad or maybe a relay not working right in the box? Did you do the testing MSD suggests to find the problem?
