msd ingintion components - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2013, 09:29 PM
don't understand what I may of be doing incorrect, keep burning coils.
Old 02-06-2013, 01:32 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
We need a lot more information than that.
When does it happen, what vehicle, system, distributor, which MSD box, how's it wired, etc.
Semper Fi
Old 02-06-2013, 07:57 AM
delawarebill's Avatar
smoke testing coils
ck your info on the dizzy. u may need a ballast resistor.
Old 02-06-2013, 09:18 AM
msd
6200 series box with a marine non vacuum msd distributor, wired per instruction, use two wire clip that connects to the distributor and tied off the white wire with a cap. Vehicle is ground well cab, engine and battery neg is ground to frame with clean connection. Box is connected heavy red and black which are 10 ga directly to battery + and -. Motor runs for a while then dies coil is done. Engine is a stock crate 305 using msd ingintion components, charging system is on line at 13.5
Old 02-06-2013, 11:25 AM
33Willys77's Avatar
What type of plug wires? Orange wire from box to + on coil and small black to - on coil. Should need nothing more on the coil. Solid core wires can not be used with MSD. Are you sure the coil is going bad or maybe a relay not working right in the box? Did you do the testing MSD suggests to find the problem?
Old 02-06-2013, 02:22 PM
Plug wires are new 8.8 accel, wired per MSD instruction, have signal jumpering the distributor wires per MSD tec guy walked though wiring with them on the phone to verify, sending box in under warranty. TEC said sound like it's wired correctly
Old 02-06-2013, 05:26 PM
T-bucket23's Avatar
Wiki Edits: 26
Generally coils burn due to over current due to bad connections or a charging system that is not functioning correctly. You dont have anything but the MSD box wires connected to the coil do you. This is a no no with MSD
Chet
Old 02-06-2013, 05:53 PM
Only wires to the coil are from the msd box per the instruction unless I missed something at this point any help will be taken
Ignition wires MSD or f.e. ACCEL to MSD pro-billet & digital-6?? Berres Electrical 4 11-27-2009 02:17 PM
Question about hooking a msd blaster coil to a msd dizzy tiresmoke55 Engine 4 04-29-2008 04:41 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 03:16 PM
MSD 7AL vs Msd digital 6 in a race car? mr_chickenhead Engine 9 12-08-2003 11:04 PM
