MSD MAP sensor for vacuum curve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2010, 02:41 PM
Can I use the MAP sensor on my programmable 6AL2 to map the curve for my vacuum distributor?
Old 08-11-2010, 04:34 PM
Overdriv's Avatar
I'm not really sure where you are going with this. The MAP sensor wiring is an input used to map a Boost retard.
The map sensor will see the same manifold signal, assuming you have your vacuum advance connected to a manifold source.
To that end, enlighten me on what you have in mind??
Old 08-11-2010, 05:11 PM
If the circuitry only takes out timing then I guess it's a no go. However, if the MSD could read the vacuum and add timing as the vacuum builds then I could use it to add timing during cruise and of course still withdraw with drop in vacuum.
Old 08-11-2010, 06:56 PM
Overdriv's Avatar
Actually the Map sensor and the MSD only see pressure. The software may convert to vacuum for the user??
Low pressure (high vacuum)= no boost retard
High pressure (low vacuum)= boost retard
You should read the instructions that came with your MSD. And read the instructions for the software program they supply. It's hard telling what you might dream up to do. Good luck.
misfire @cruising speeds MSD digital E curve Distributor dawg Engine 8 07-04-2008 11:35 AM
anyone running the MSD digital E curve pro billet distributor? dawg Engine 0 02-09-2008 01:58 PM
Mallory Unilite timing curve adjustment frankenvette Engine 2 05-14-2007 10:12 AM
MSD E curve distributer # 8394 ccnova Engine 3 12-17-2004 07:45 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
