MSD Pro Billet - which adjustable Vacuum Advance?
I'm trying to find a vacuum advance canister that will correctly fit a MSD Pro Billet Distributor. In the picture below, the canister on the left is the MSD canister. The canister on the right is a Jegs adjustable canister for an HEI (I read somewhere else that it fits
). See the mounting holes? Note the location of the rod? The rod is actually just a bit larger on the Jegs unit as well. I need one that lines up better. I really don't want to drill and tap the MSD housing. Any thoughts? ![]() Edit: I found this one (googled it). Can anyone confirm fit and function? http://www.summitracing.com/parts/CRN-99601-1/ Last edited by Big Mouse; 10-15-2010 at 06:29 AM. |
This thread will cover some of the info you are looking for:
msd pro billet dist. 8361, anyone use the vacuum advance with a stout cam? The crane part may be the one if your dist is the same as the OP's: http://www.summitracing.com/parts/CRN-99601-1/ |
at the end of the thread i linked the op says the can fits
Found this site: http://www.67chevyii.com/updates/body20.htm
He bounces around a bit (many pages) but discusses this exact conversion. Here is his home-made limiting plate solution with Crane unit installed (grind length to get correct amount of advance): ![]() Thanks a bunch guys! |
| Ignition Timing Questions | skizot | Engine | 27 | 10-27-2010 11:53 AM |
| timing advancing on its own. with no advance hooked up | glhx | Engine | 11 | 05-17-2009 09:14 AM |
| adjustable vacuum advance | brian400ex | Engine | 5 | 05-06-2009 11:10 PM |
| Edelbrock 750 tuning | GCD1962 | Engine | 42 | 04-16-2008 06:03 PM |
| running no vacuum advance | oregon chevelle | Engine | 30 | 02-07-2007 07:17 PM |
