msd pro billet dist. 8361, anyone use the vacuum advance with a stout cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2010, 08:38 PM
Last journal entry: pro systems carb
The vacuum can needs 15 inches to pull timing advance my BBC only makes 7 to 10 inches. Has anyone found an adjustable vacuum can that fits this dist. I chatted with sales at summit racing they had no luck finding anything that fit.
Old 07-30-2010, 07:42 AM
Thanks f-bird that's the best explanation yet! This should be a sticky, the msd part number is 8463 I can't post a link to summit because I'm posting from my phone. The vacuum can from bolt holes to rod is shorter than most I've seen, I emailed summit , they said they didn't have an adjustable vacuum can that fit? They may not know that they do. The combo is a 454 BBC, ls6 short block, 254/263@50 duration 620/629 lift, 3500 convertor, 3.73 gears , 325/50 bfg radials, 10.5 to 1 compression.
Old 07-30-2010, 10:51 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
OK I am as we speak right in the middle of setting my mechanical advance limit. I agree with you Fbird my setup likes allot of initial so I must limit my mech. I have a off shore HEI that is most likely the same as thousands out there, not sure how it compares to the OP's but it may help others too with the same. I am shooting for 34 total on my vortec head 383 with 221 duration @ 50. I would like 20 or 22 initial/base so if I can add say 12-14 with the mech then lets try that. This HEI will not accept a bushing kit so I am using a small machine screw/nut through the rotor plate, the head of the screw will butt against the advance plate stopping its movement. This HEI had over 20 deg mech to start with. I would like to see if I can ball park this stopper with the dist. out of the engine by using a degree method. I have installed a pointer on the rotor plate and measured the movement of the pointer from no mech to its limit. The diameter of the dist body is 132mm, the travel of the pointer is 17mm, If say 6 deg on the pointer makes 12 at the crank right? or is it the other way around? how close am I? I would like to use some math to see if I have the right deg movement...anybody?
ID:	47075   Click image for larger version
ID:	47076   Click image for larger version
Old 07-30-2010, 11:15 AM
Custom10's Avatar
Well I am answering my own question C/D= 3.14 were C is circumference and D is diameter so 132 X 3.14 = 414.5 divided by 360 = 1.15 mm per deg approx so I get 19.55 deg movement is that 9.8 crank Deg? looking for some confirmation. Am I on the right track here or will this little exercise shoot itself in the foot somehow?
Old 07-30-2010, 11:29 AM
Custom10's Avatar
I should note that I respect the initial OP's question on vacuum advance and although my post does not address this directly yet, this may be useful if he is setting up the mech limit first off to get to what Fbird is making posts on, I will try and keep it relevant and add some vacuum adjustment details as we go along if need be
Old 07-30-2010, 11:57 AM
Custom10's Avatar
Originally Posted by F-BIRD'88
Ya the distributor runs at half crankshaft speed.
OK I have tweaked the stopper to get about 21mm movement that should equate to approx 12 deg at the crank thanks to mechanical. I will post when I get it in and set the light on it. Thanks
Old 07-30-2010, 05:34 PM
Custom10's Avatar
Ended up with 17 deg added by mech on the running engine with the 21mm advance travel. In this case I will set my base at 17 as well to get my 34 total without vac advance. My cam is not that big so this is OK for now but I may want to get my base up further sometime, that means getting back in there and changing the stop point...again. SO 21mm/17deg = .81 wonder if we can use this ratio? would setting the mech movement limit to 15mm travel have given the 12.15 deg I was looking for? (15 x .81 = 12.15) just a ballpark procedure maybe
One thing I found was that my adjustable vac can had a slow leak, it would bleed down really slow, the leak was were the sleeve for the hose meets the vac can, the OEM one I replaced it with is one molded piece or at least braised at this connection and tested good, by the way it adds another 22 without a limiter so back in I go once I get a new adjustable can.
Old 07-30-2010, 06:18 PM
Hmmm, still looking for an adjustable can for 836
1 msd dist. as stated in the thread title.
Old 07-30-2010, 07:00 PM
Custom10's Avatar
Yeah got ya, did not mean to fill your thread with my own ramblings should have started new one on this, was relavent to a point but not helping you much...my bad.
Old 07-30-2010, 07:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Can you show a photo of it w/a ruler in the shot- there may be a GM (or other) can that'll fit it.
Summit sells a can- http://www.summitracing.com/search/B.../?autoview=SKU
But doens't say it is adjustable, and I take it you've checked yours for an adjustment?
EDIT- Does it look like a GM points unit?
Old 07-30-2010, 07:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A little hard to tell from these images. The HEI can has a longer bracket than either of these- and the two are not interchangeable. I bet the points-type GM can will fit the MSD distributor, though.
ACCEL ADJUSTABLE GM POINTS-TYPE
MSD REPLACEMENT
Old 07-30-2010, 09:44 PM
Greg T's Avatar
www.krusinklassics.net
The 8361 uses a GM point style vac can. So a Crane 99601-1 will do the trick
Old 07-31-2010, 08:16 AM
Tanks cobalt, those are good pic's, just need someone who has one running with a different can that's adjustable.
Old 07-31-2010, 09:08 PM
perfect, thanks greg t and fbird, ordering this week.
Old 07-31-2010, 10:03 PM
Greg T's Avatar
The 99601-1 is out of stock at Summit. Should ship by about the 10th. I'm waiting for one.
cam questions novaboy72 Engine 3 05-28-2010 01:33 AM
timing question Radchop Engine 7 11-19-2008 09:16 PM
Edelbrock 750 tuning GCD1962 Engine 34 04-16-2008 06:03 PM
Quick Ignition Question- Digital tach MSD Pro Billet dist biggeazy-e Engine 2 06-03-2007 09:20 PM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 05:04 PM
