MSD problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2009, 09:25 PM
MSD problems
Ok so I hook up my new Demon carb today everything running is great. I have an electric choke on the carb so decided to hook it up. It says you need a switched/12v power source and a ground. So I splice it into the switched 12/v source for the MSD (6A2) box because it is also a swtich 12/v. Run it down the road and seem fine. I park it and try to shut it off.....won't shut off. Like the Coil is getting a constant 12/v. Choke the car out to shut it off.
Start to trouble shoot this so I unhook the Electric choke and hook the MSD back up exactly like it was before....nothing happens no power to the coil. Hook it up to a constant 12/v and the car starts but won't shut off. I'm stumped! I know I should try finding another switched 12/v power source but the source I was using has power going to it...what gives? Why won't it start when hooked up to a switched source?
Old 09-28-2009, 08:36 PM
OLNOLAN's Avatar
Msd Issue
Hey Man, Did you get it figured out yet? Sounds like you maybe have some wires crossed up. I don't know what kind of car you're working on but a 6al setup is pretty easy to hook up. The big red and the big black wires should be fed direct from the battery. The smaller red wire goes to a switched ignition 12v(from the key). The orange and black wires go to the coil. Don't tie any other wires into the coil circuit as they are high voltage from the MSD box. If you connected the choke to the same small red wire that turns on the MSD box, the MSD box might not like the extra load from the electric choke coil. I'm not sure if it matters though. It seems like you have your constant and switched circuits crossed up? olnolan
Old 10-03-2009, 08:56 PM
choke hook uo to your battery terminal on alternator. MSD just as above post states
Old 10-04-2009, 12:27 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I take it you are running an internal regulated alternator.
You will need to install a diode in the key on power wire, to the voltage regulator to get the engine to shut off.
Question about hooking a msd blaster coil to a msd dizzy tiresmoke55 Engine 4 04-29-2008 03:41 PM
Anyone had any problems with MSD coils lately? TRLBLAZR60 Engine 7 11-15-2007 09:33 PM
Summit Ignition System vs MSD Harley Monster Engine 4 07-22-2007 04:09 PM
MSD CD Boxes reliable? Derkyb Electrical 2 06-11-2007 11:00 AM
MSD Set-Up Question. GMCTRUCKS Electrical 2 03-12-2007 12:13 AM
