MSD Timing master wiring
Hi Everybody: I have an Old MSD Timing master 8770 it has the same wiring as the Timing computer BUT it only has a gray wire for the toggle switch. the Timing computer has a black wire and a gray wire to be hooked to the toggle. I have tried working with MSD them selves but the best they could do was " that part number doesn't exist, Are you sure it was made by MSD?". My actual question is do i hook the gray wire to a toggle and then the toggle to ground? Sorry I don't post very often. I just want to use this for starting retard on a locked out ignition system, Race only application. Thanks
Go to the MSD site and into the tech forum and search "8770 timing master". I just took a look and there is a thread concerning hook-up of the older Timing Master and how to determine if the grey wire should be hooked to ground or the opposite.
| EZ wiring - back up light wiring | copdwg | Electrical | 3 | 06-07-2008 06:42 PM |
| Does anyone have a wiring diagram for a Mallory #600 timing advance computer...? | Bumpstick | Electrical | 3 | 04-07-2007 11:52 PM |
| Timing sbc corvette timing at 12o clock on both gears? | 85 vette | Engine | 21 | 12-22-2004 08:23 PM |
| trying to setting the timing on the timing chain and gears on a 74 ply with a 318 | ReggieN | Engine | 1 | 10-05-2004 07:54 AM |
| Trust the timing light or the timing pointer? | lluciano77 | Engine | 6 | 03-06-2004 01:35 AM |
