MSD Ultimate HEI Upgrade Kits - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2008, 01:33 PM
10mikeymike's Avatar
I'm considering one of the MSD Ultimate HEI Upgrade kits for my GM HEI ignition. Does anyone have any experience with these? Is this just a parts swap or does it necessitate readjusting the timing, etc?
Old 09-15-2008, 07:07 PM
Rhansen's Avatar
Footbraker
If you're talking about P/N 8501, it is just a parts swap. I ran one for a few years on a mild SBC with no complaints. Picked it up after having some high rpm misfires related to a few (poor quality) ignition modules.
Old 09-16-2008, 06:09 AM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
The MSD HEI module is a little tougher to get in and out of the ditributor body, I found it necessary to remove the distributor from the engine to mount it properly. In that respect you will have to re-set the timing when you re-install it. I wouldn't expect it to change anything else though.
I went with the matching MSD coil and was impressed with the increased spark output - especially at higher RPM.
"Wiring Harness" docvette Electrical 185 10-30-2011 04:17 PM
Summit HEI Upgrade Fergusonic Electrical 1 08-31-2008 03:34 PM
engine kits michelobmike2004 Engine 1 01-04-2007 08:58 AM
HEI Upgrade!! ss396si Electrical 6 03-13-2005 07:46 AM
HEI help...before I go crazy EricTopless68 Camaro Engine 13 09-29-2003 09:08 AM
