is this to much cam...?
ok building a mild 350 motor for a daily driver for a buddy.... he has a set of 2.02 heads and a stock bottom end 350... the heads have been millied for more compresion... the motor is going in a 89 1/2 ton truck.... this is a cam i found would it be to big ...if so what would be a good pick.... he was very spacific on wanting it to sound radical... ( i tryed to explain it would suck to drive) but i will do what he wants.....
CAMSHAFT SPECIFICATIONS
Valve Lift -- Int."/Exh." .488/.509
.050" Duration -- Int./Exh. 234/244
Lobe Seperation Angle 107/117
