cam
A lot of cam manufacturers offer retro "sounding" cams that work well.They are similar to the old GM 350 hp 350 cam. Use a hydraulic flat tappit cam for that lumpier idle.With stock compression a 106 degree intake centre line have a bumpier idle compared to 110 or 112. 450 lift is probably enough.really depends on how high you want to rev ,,,use headers on this application as stock manifolds seem to tame the cams sound a little.270 ish advertised duration is plenty
